Api session event editor measure set grid automatic polygons
API Endpoint: editormeasure/set_grid_automatic_polygons.
Description: Let the polygons be calculated automatically based on the Overlay specified in the Grid spatial of a Measure.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure ID | |
| 1 | REQUIRED | (Integer number) | Grid Spatial ID | |
| 2 | REQUIRED | (true, false) | Automatic calculation | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_grid_automatic_polygons/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, false ]'JavaScript example POST:
body: '[ 1, 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_grid_automatic_polygons/", options)
