Api session event editor measure set geotiff automatic polygons
Revision as of 13:36, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormeasure/set_geotiff_automatic_polygons.
Description: Let the polygons be calculated automatically based on the GeoTIFFs specified in the GeoTIFF spatial of a Measure.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (Integer number) GeoTIFF Spatial ID
2 REQUIRED (true, false) Automatic calculation true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_geotiff_automatic_polygons/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, false ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_geotiff_automatic_polygons/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST:
 body: '[ 1, 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_geotiff_automatic_polygons/", options)
