Api session event editor measure add upgrade
Revision as of 13:35, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormeasure/add_upgrade.
Description: Add a new Upgrade Spatial to a Measure.
0 REQUIRED (MEASURE Integer ID) Measure ID
200 Integer (Upgrade Spatial ID)
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_upgrade/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_upgrade/", options)
