Api session event editor map set height geotiff
Revision as of 13:35, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormap/set_height_geotiff.
Description: Set Height GeoTIFF
0 REQUIRED (GEO_TIFF Integer ID or multiple values in array [1, 2, 3]) GeoTIFF
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editormap/set_height_geotiff/", options)
