Api session event editor geolink duplicate
Revision as of 13:33, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorgeolink/duplicate.
Description: Duplicate existing Geo Link
0 REQUIRED (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) Geo Link
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/editorgeolink/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeolink/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/duplicate/", options)
