Api session event editor geolink add
Revision as of 13:33, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorgeolink/add.
Description: Add new Geo Link
0 REQUIRED (GeoLinkType or multiple values in array [a, b, c]) Geo LinkType[]
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/editorgeolink/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "AREA", "Text 1" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeolink/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "AREA", "BUILDING", "ROAD" ], [ "Text 1", "Text 2", "Text 3" ] ]'
JavaScript example POST:
 body: '[ "AREA", "Text 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/add/", options)
