Api session event editor chat reset channel
Revision as of 13:32, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorchat/reset_channel.
Description: Reset chat channel contents
0 REQUIRED (Integer number) Channel ID
200 Boolean (Found channel and removed messages returns true otherwise false)
curl 'https://engine.tygron.com/api/session/event/editorchat/reset_channel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorchat/reset_channel/", options)
