Api session event editor building multi select
Revision as of 13:31, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorbuilding/multi_select.
Description: Multi Select
0 REQUIRED (FUNCTION Integer ID) Function
1 REQUIRED (Integer number) Integer
2 REQUIRED (true, false) Boolean true or false
3 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorbuilding/multi_select/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, false, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/multi_select/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true, [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, 1, false, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/multi_select/", options)
