Api session event editor attributeaction set description
API Endpoint: editorattributeaction/set_description.
Description: Set Description
| 0 | REQUIRED | (ATTRIBUTE_ACTION Integer ID or multiple values in array [1, 2, 3]) | Attribute Action | |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text 1" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]'JavaScript example POST:
body: '[ 1, "Text 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorattributeaction/set_description/", options)
