Levee Type
What are Dikes?
In spatial planning Dike or dyke refers to a natural or artificial slope or wall to regulate water levels, called levee in US English.
For more information, see also: https://en.wikipedia.org/wiki/Dyke & https://en.wikipedia.org/wiki/Levee
Three distinct implementations of Dikes
River Flood Protection
Along some of the larger rivers in the world (Rhine, Mississippi) elaborate levee structures have been constructed to prevent the river and its delta from flooding the banks.
Coastal Flood Protection
Many coastal flatlands are protected by complex flood defenses, for example the sea wall at Vancouver BC (Canada). An extreme example is the Netherlands, where huge levee structures such as the Delta works protect against coastal inundations. Besides protecting the landmass, these huge dikes are also used in the Netherlands to claim more land that was originally below mean sea level.
Spur dykes or groynes
These man made constructions are implemented as erosion prevention. These dikes are usually constructed at an angle to the bank or coast, and can be found in inland rivers and canals, and at the sea coast. They are for instance deployed in the 'Room for the Rivers' project in the Netherlands to counter bank erosion.
How do Dikes relate to the Tygron Engine?
Water management is an important factor of spatial planning. Dikes (or levees) are some of the most basic water management measures that can be implemented; just build a wall and keep the water out!
In the Tygron Engine these Dikes play a special part. As dedicated constructions they can affect safe zone terrains and floods. By constructing a Dike as an independent action or as part of a measure, the safe zone terrain will be expanded, protecting more houses and industry when a flood occurs. This can all be visualized in the Tygron Engine and a dedicated indicator can be set up to have the implementation of levees score on the stakeholder progression.
Different ways of deploying Dikes in the Tygron Engine
In the Tygron Engine are two ways present to implement Dikes in a project; drawn in manually during the session as action, or deployed as part of a (predefined) measure.
Implementation as action allows for trying out new plans and ideas. This can for instance be convenient when the project is part of an outreach to non-planners, for example residents or business owners, to let them try their own plans and ideas without an engineer pre-planning the flood protection for them. This can give session participants a stronger sentiment of involvement with the project.
On the other hand, deploying the dikes as part of a predefined measure enables a project to quickly switch between different pre-planned alignments, in order to visualize the impact of each alignment on the indicators.
Manually drawn in as an Action
Template:Editor ribbon
How to implement dikes/ levees as Action:
  1. Select 3D World → Dike Types → Add new Dike Type
  2. Select the newly created Dike entry in the left panel
  3. On the right panel, change the name to something more suitable
  4. Change the image, or upload a new image
  5. Enter a description to describe the new levee
  6. Change or remove the top and side function of the dike
  7. Select the check box in case the levee has a fixed size
  8. Enter default height and width
  9. Select Stakeholders → Actions
  10. Add a new action (if desired)
  11. Highlight Assigned Actions
  12. Add new levee to Assigned actions by marking check box on right panel
Editing properties of a Dike as Action
The following properties can be edited of a new or already existing Dike that is set up as an action:
Name
In the name field ion the right panel, the default name can be replaced by entering a more suitable name. This can be for instance a reference to the top and side functions (see below).
Description
Top & side functions
Fixed size
Height & width
Deployed as part of a (predefined) Measure
Note: it is currently only possible to assign functions to the top and side of a dike when deployed as an Action.
How to implement dikes/ levees as predefined Measure:
  1. Select Stakeholders → Measures → Add Spatial Measure
  2. Open the MeasureSpatials entry
  3. Select the WATER 1 (default) entry
  4. On the right panel, select DIKE as type from the drop down menu on the right panel
  5. Set relative and absolute height on the right panel
  6. Use brush panel to draw Outer Area, and apply
  7. Use brush panel to draw Inner Area, and apply
  8. Select Stakeholders → Actions
  9. Add new action (if desired)
  10. Select Assigned Actions
  11. Add new Measure to Assigned Actions on the right panel
Properties of a Dike as (predefined) Measure
Type
Relative and absolute height
Outer area
Inner area
