Api session event editor actionmenu swap order
Revision as of 13:30, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editoractionmenu/swap_order.
Description: Swap Order
0 REQUIRED (ACTION_MENU Integer ID or multiple values in array [1, 2, 3]) Action Menu
1 REQUIRED (ACTION_MENU Integer ID or multiple values in array [1, 2, 3]) Action Menu
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/swap_order/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/swap_order/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoractionmenu/swap_order/", options)
