Api session event editor overlay swap order
Revision as of 13:02, 13 April 2026 by Maxim@tygron.com (talk | contribs)
API Endpoint: editoroverlay/swap_order.
Description: Swap Order
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay
1 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/swap_order/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/swap_order/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/swap_order/", options)
