Api session event editor overlay set visible
API Endpoint: editoroverlay/set_visible.
Description: Visualizes or hides an Overlay in the navigation Panel.
| 0 | REQUIRED | (OVERLAY Integer ID or multiple values in array [1, 2, 3]) | Overlay ID | |
| 1 | REQUIRED | (Boolean or multiple values in array [true, false, true]) | Visualized |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_visible/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_visible/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'JavaScript example POST:
body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_visible/", options)
