Api session event editor overlay set prequel
Revision as of 13:02, 13 April 2026 by Maxim@tygron.com (talk | contribs)
API Endpoint: editoroverlay/set_prequel.
Description: Set prequel Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (OVERLAY Integer ID) Prequel Overlay ID
2 REQUIRED (String) Prequel Type Name
3 OPTIONAL (Integer number) Prequel Timeframe ID (optional)
4 OPTIONAL (true, false) Previous Iteration (optional)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_prequel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Prequel Type Name", "", "" ]'
JavaScript example POST:
 body: '[ 1, 1, "Prequel Type Name", "", "" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_prequel/", options)
