Api session event editor overlay set overlay image
Revision as of 13:02, 13 April 2026 by Maxim@tygron.com (talk | contribs)
API Endpoint: editoroverlay/set_overlay_image.
Description: Change the image displayed by a specified IMAGE Overlay. The image must be uploaded in the "Overlay" directory.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay IDs (must relate to an IMAGE Overlay)
1 REQUIRED (String or multiple values in array ["a", "b", "c"] or matrix [["a", "b"], ["c", "d"], ["e", "f"]]) Array of Project asset names, omitting the directory
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "A1", "B1" ] ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ [ "A1", "B1" ], [ "A2", "B2" ], [ "A3", "B3" ] ] ]'
JavaScript example POST:
 body: '[ 1, [ "A1", "B1" ] ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_image/", options)
