Api session event editor overlay set neural network
API Endpoint: editoroverlay/set_neural_network.
Description: Set the Neural Network for an Inference Overlay.
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID (must relate to a Inference Overlay) | |
| 1 | REQUIRED | (NEURAL_NETWORK Integer ID) | Neural Network ID |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_neural_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_neural_network/", options)
