Api session event editor overlay set net overlay
API Endpoint: editoroverlay/set_net_overlay.
Description: Set the visualization style for a specified network Overlay.
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID (must relate to a network Overlay) | |
| 1 | REQUIRED | (Enumeration) | NetType | ELECTRICITY, GAS, HEAT, INTERNET or SEWER |
| 2 | REQUIRED | (true, false) | Whether to show the network (false means no lines will be visualized) | true or false |
| 3 | REQUIRED | (true, false) | Whether only active connections should be visualized (false means both active and inactive connections are visualized) | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_net_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "ELECTRICITY", true, false ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_net_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "ELECTRICITY", true, true ]'JavaScript example POST:
body: '[ 1, "ELECTRICITY", true, false ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_net_overlay/", options)
