Api session event editor overlay set legend entry name
Revision as of 13:02, 13 April 2026 by Maxim@tygron.com (talk | contribs)
API Endpoint: editoroverlay/set_legend_entry_name.
Description: Change the name of a specified legend entry of a custom legend of a specified Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (true, false) Affect the custom difference legend (false means affect the normal custom legend) true or false
2 REQUIRED (Integer number) ID of entry which should be changed
3 REQUIRED (String) New name for the entry
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_legend_entry_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true, 1, "New name for the entry" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_legend_entry_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false, 1, "New name for the entry" ]'
JavaScript example POST:
 body: '[ 1, true, 1, "New name for the entry" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_legend_entry_name/", options)
