Api session event editor overlay set attribute overlay values
API Endpoint: editoroverlay/set_attribute_overlay_values.
Description: Set which type of item and which attribute a specified ATTRIBUTE Overlay should highlight. The ATTRIBUTE Overlay will highlight each item it finds which is both of the specified maptype as well as has the specified attribute
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID (must relate to an ATTRIBUTE Overlay) | |
| 1 | REQUIRED | (Enumeration) | MapLink: AREAS, BUILDINGS, NEIGHBORHOODS, NET_LOADS, TERRAINS, ZONES | ACTION_LOGS, ACTION_MENUS, ADDRESSES, AREAS, ATTRIBUTE_ACTIONS, BUILDINGS, CHAT_MESSAGES, CINEMATIC_DATAS, CLIENT_WORDS, COSTS, CUSTOM_GEOMETRIES, DEFAULT_WORDS, ERROR_LOGS, EVENT_BUNDLES, EXCEL_SHEETS, FUNCTION_OVERRIDES, FUNCTIONS, GEO_LINKS, GEO_OPTIONS, GEO_PLUGINS, GEO_TIFFS, GLOBALS, HEIGHTS, INCOMES, INDICATORS, LEVEES, MEASUREMENTS, MEASURES, MODEL_DATAS, MODEL_SETS, MONEY_TRANSFERS, NEIGHBORHOODS, NET_CLUSTERS, NET_FUNCTIONS, NET_LINES, NET_LOADS, NET_NODES, NET_SETTINGS, NEURAL_NETWORKS, OVERLAYS, PANELS, PARAMETRIC_DESIGNS, PARAMETRIC_EXAMPLES, PARTICLE_EMITTERS, PLOTS, POPUPS, PROGRESS, PROJECT_ASSETS, RECORDINGS, SCENARIOS, SERVER_WORDS, SETTINGS, SOUNDS, SOURCES, SPECIAL_EFFECTS, SPECIAL_OPTIONS, STAKEHOLDERS, TERRAIN_TYPE_OVERRIDES, TERRAIN_TYPES, TERRAINS, TEXTURES, TIMES, TRIGGERS, UNIT_DATA_OVERRIDES, UNIT_DATAS, UPGRADE_TYPES, WATER_VALUES, WEATHERS, ZIP_CODES or ZONES |
| 2 | REQUIRED | (String) | Attribute to look for |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_attribute_overlay_values/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SETTINGS", "Attribute to look for" ]'JavaScript example POST:
body: '[ 1, "SETTINGS", "Attribute to look for" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_attribute_overlay_values/", options)
