Api session event editor overlay duplicate
Revision as of 13:01, 13 April 2026 by Maxim@tygron.com (talk | contribs)
API Endpoint: editoroverlay/duplicate.
Description: Duplicate existing Overlay
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/editoroverlay/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/duplicate/", options)
