How to calculate the hourly radiation
Revision as of 12:27, 13 April 2026 by Frank@tygron.nl (talk | contribs)
According to the DPRA Heat stress report:
"De globale straling van het KNMI station is een som van het afgelopen uur. Om de hoeveelheid straling op het hele uur te schatten wordt de straling van het komende uur en afgelopen uur gemiddeld."
So the global radiation for the hour has to be calculated as the average of the past hour and the next hour. We use the Q column from the KNMI weather data for this. Additionally, the global radiation is in J / cm2 and has to be converted to W / m2 by multiplying:
radiationhourly=Qt+Qt+12100003600
Column Name Unit Dutch Description
13/L Q J/cm2 Globale straling (in J/cm2) per uurvak;
  • The values at each hour regard the measurement over the preceding hour up to that time. To obtain the value for 10:00 UTC, the values at 10:00 UTC and 11:00 UTC must be used.
