Api session event editor building set owner
API Endpoint: editorbuilding/set_owner.
API Endpoint name is Api session event editor building set owner.
Use this endpoint to Set the Owner (ID) of a Building.
| Name | Importance | Type | Description | Endpoint |
| 0 | REQUIRED | (BUILDING Integer ID or multiple values in array [1, 2, 3]) | Building ID | https://engine.tygron.com/api/session/items/buildings/?f=JSON&token=API_TOKEN |
| 1 | REQUIRED | (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) | Owner ID | https://engine.tygron.com/api/session/items/stakeholders/?f=JSON&token=API_TOKEN |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_owner/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_owner/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/set_owner/", options)
