Api session event editor building set owner
Revision as of 14:15, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorbuilding/set_owner.
API Endpoint name is Api session event editor building set owner.
Use this endpoint to Set the Owner (ID) of a Building.
Owner ID of a building can be inspected using the endpoint https://engine.tygron.com/api/session/items/buildings/0/ownerID/?f=JSON&token=API_TOKEN
Possible owner IDs can be obtained from using the ID of stakeholders obtained using the endpoint https://engine.tygron.com/api/session/items/stakeholders/?f=JSON&token=API_TOKEN
Name Importance Type Description Endpoint
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building ID https://engine.tygron.com/api/session/items/buildings/?f=JSON&token=API_TOKEN
1 REQUIRED (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) Owner ID https://engine.tygron.com/api/session/items/stakeholders/?f=JSON&token=API_TOKEN
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_owner/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_owner/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/set_owner/", options)
