Api session event editor stakeholder set image
Revision as of 12:01, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorstakeholder/set_image.
API Endpoint name is Api session event editor stakeholder set image.
Use this endpoint to Set Image
0 REQUIRED (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) Stakeholder
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text 1" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]'
JavaScript example POST:
 body: '[ 1, "Text 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/set_image/", options)
