Api session event editor sound set loop
Revision as of 12:00, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorsound/set_loop.
API Endpoint name is Api session event editor sound set loop.
Use this endpoint to Set Loop
0 REQUIRED (SOUND Integer ID) Sound
1 REQUIRED (true, false) Boolean true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsound/set_loop/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'
JavaScript example POST:
 body: '[ 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editorsound/set_loop/", options)
