Api session event editor overlay set image
API Endpoint: editoroverlay/set_image.
API Endpoint name is Api session event editor overlay set image.
Use this endpoint to Change the icon displayed in the navigation window by the Overlay. Only existing Overlay Project Asset are allowed.
| 0 | REQUIRED | (OVERLAY Integer ID or multiple values in array [1, 2, 3]) | Overlay ID | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Project asset name, omitting the directory |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Project asset name, omitting the directory 1" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Project asset name, omitting the directory 1", "Project asset name, omitting the directory 2", "Project asset name, omitting the directory 3" ] ]'JavaScript example POST:
body: '[ 1, "Project asset name, omitting the directory 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_image/", options)
