Api session event editor overlay set name
API Endpoint: editoroverlay/set_name.
API Endpoint name is Api session event editor overlay set name.
Use this endpoint to Set the name for a specified Overlay.
| 0 | REQUIRED | (OVERLAY Integer ID or multiple values in array [1, 2, 3]) | Overlay ID | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Name for the Overlay |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Name for the Overlay 1" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Name for the Overlay 1", "Name for the Overlay 2", "Name for the Overlay 3" ] ]'JavaScript example POST:
body: '[ 1, "Name for the Overlay 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_name/", options)
