Api session event editor neuralnetwork export
Revision as of 11:56, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorneuralnetwork/export.
API Endpoint name is Api session event editor neuralnetwork export.
Use this endpoint to Export
0 REQUIRED (NEURAL_NETWORK Integer ID) Neural Network
200 byte[] (byte array)
curl 'https://engine.tygron.com/api/session/event/editorneuralnetwork/export/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorneuralnetwork/export/", options)
