Api session event editor netsetting set owner
Revision as of 11:56, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editornetsetting/set_owner.
API Endpoint name is Api session event editor netsetting set owner.
Use this endpoint to Set Owner
0 REQUIRED (Enumeration) NetType ELECTRICITY, GAS, HEAT, INTERNET or SEWER
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_owner/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ELECTRICITY", 1 ]'
JavaScript example POST:
 body: '[ "ELECTRICITY", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetsetting/set_owner/", options)
