Api session event editor netcluster remove network
API Endpoint: editornetcluster/remove_network.
API Endpoint name is Api session event editor netcluster remove network.
Use this endpoint to Remove Network
| 0 | REQUIRED | (Enumeration) | NetType | ELECTRICITY, GAS, HEAT, INTERNET or SEWER |
| 1 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetcluster/remove_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ELECTRICITY", true ]'JavaScript example POST:
body: '[ "ELECTRICITY", true ]'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/remove_network/", options)
