Api session event editor netcluster generate clusters
API Endpoint: editornetcluster/generate_clusters.
API Endpoint name is Api session event editor netcluster generate clusters.
Use this endpoint to Generate Clusters
| 0 | REQUIRED | (NetType or multiple values in array [a, b, c]) | NetType[] | |
| 1 | REQUIRED | (Enumeration) | ClusteringType | ADD_TO_EXISTING_FOR_BUILDINGS, MAP_SECTORS, PER_ATTRIBUTE, PER_BUILDING, PER_LOAD or PER_LOAD_UNIQUE_OWNER |
| 2 | REQUIRED | (MultiPolygon with crs: EPSG:3857) | MultiPolygon | |
| 3 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Integer[] | |
| 4 | REQUIRED | (Floating point number) | Double | |
| 5 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 6 | REQUIRED | (String) | String | |
| 7 | REQUIRED | (true, false) | Boolean | true or false |
| 8 | OPTIONAL | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetcluster/generate_clusters/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ "ELECTRICITY", "PER_LOAD", {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 1, 69, 1, "Text", true, "" ]
'Curl example multi item POST:
[ [ "ELECTRICITY", "GAS", "HEAT" ], "PER_LOAD", {
}, [ 1, 2, 3 ], 99, 1, "Text", true, "" ]
'JavaScript example POST:
body: '[ "ELECTRICITY", "PER_LOAD", { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, 1, 69, 1, "Text", true, "" ]'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/generate_clusters/?crs=3857", options)
