Api session event editor neighborhood add
Revision as of 11:55, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorneighborhood/add.
API Endpoint name is Api session event editor neighborhood add.
Use this endpoint to Add new Neighborhood
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorneighborhood/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ ]'
JavaScript example POST:
 body: '[ ]'
fetch("https://engine.tygron.com/api/session/event/editorneighborhood/add/", options)
