Api session event editor measure set requires confirmation
API Endpoint: editormeasure/set_requires_confirmation.
API Endpoint name is Api session event editor measure set requires confirmation.
Use this endpoint to Set whether the Measure should be confirmed by other Stakeholder.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure ID | |
| 1 | REQUIRED | (true, false) | Confirmation Required Boolean | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_requires_confirmation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_requires_confirmation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'JavaScript example POST:
body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_requires_confirmation/", options)
