Api session event editor measure set image
API Endpoint: editormeasure/set_image.
API Endpoint name is Api session event editor measure set image.
Use this endpoint to Set the image of a Measure.
| 0 | REQUIRED | (MEASURE Integer ID or multiple values in array [1, 2, 3]) | Measure IDs | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Image names |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Image name 1" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Image name 1", "Image name 2", "Image name 3" ] ]'JavaScript example POST:
body: '[ 1, "Image name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_image/", options)
