Api session event editor measure import buildings
Revision as of 11:54, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormeasure/import_buildings.
API Endpoint name is Api session event editor measure import buildings.
Use this endpoint to Import Measure Building Collection
0 REQUIRED (GeometryCollection with crs: EPSG:3857) Collection of Building geometries
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Building Names
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute Names
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Attribute Values
4 REQUIRED (FUNCTION Integer ID or multiple values in array [1, 2, 3]) Function
5 OPTIONAL (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) Owners (optional)
6 OPTIONAL (MEASURE Integer ID) Set for existing Measure ID (optional)
7 OPTIONAL (Floating point number) Buffer for Points and Lines to make Polygons (optional)
8 OPTIONAL (SOURCE Integer ID) Source (optional)
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/editormeasure/import_buildings/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "Building Name 1", "Attribute Name 1", [ 1.0, 2.0 ], 1, "", "", "", "" ]
Curl example multi item POST:
 "geometries" : [ {
 "coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, [ "Building Name 1", "Building Name 2", "Building Name 3" ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], [ 1, 2, 3 ], "", "", "", "" ]
JavaScript example POST:
 body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, "Building Name 1", "Attribute Name 1", [ 1.0, 2.0 ], 1, "", "", "", "" ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/import_buildings/?crs=3857", options)
