Api session event editor measure add levee
Revision as of 11:54, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormeasure/add_levee.
API Endpoint name is Api session event editor measure add levee.
Use this endpoint to Add a new Levee Spatial of a specified Levee to a Measure.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (LEVEE Integer ID) Levee ID
200 Integer (Levee Spatial ID)
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_levee/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_levee/", options)
