Api session event editor geolink remove mapping
Revision as of 11:51, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorgeolink/remove_mapping.
API Endpoint name is Api session event editor geolink remove mapping.
Use this endpoint to Remove map orginal Attribute name to a new name in the created feature.
0 REQUIRED (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) CustomGeo Link IDs
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute Names
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeolink/remove_mapping/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name 1" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeolink/remove_mapping/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ] ]'
JavaScript example POST:
 body: '[ 1, "Attribute Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/remove_mapping/", options)
