Api session event editor scenario set restart testrun
Revision as of 11:30, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorscenario/set_restart_testrun.
API Endpoint name is Api session event editor scenario set restart testrun.
Use this endpoint to When true test run is restarted on Scenario activation. This option will be deprecated in the future and replaced by multiple maps.
0 REQUIRED (SCENARIO Integer ID or multiple values in array [1, 2, 3]) Scenario ID
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Restart required
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_restart_testrun/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_restart_testrun/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript example POST:
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/set_restart_testrun/", options)
