Api session event editor scenario add measure
Revision as of 11:30, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorscenario/add_measure.
API Endpoint name is Api session event editor scenario add measure.
Use this endpoint to Add a Measure that is Triggered on Scenario activation.
0 REQUIRED (SCENARIO Integer ID) Scenario ID
1 REQUIRED (MEASURE Integer ID) Measure ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorscenario/add_measure/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/add_measure/", options)
