Api session event editor overlay set tensor normalized
Revision as of 11:28, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editoroverlay/set_tensor_normalized.
API Endpoint name is Api session event editor overlay set tensor normalized.
Use this endpoint to Set whether an input tensor of an Inference Overlay should be normalized when provided to a Neural Network.
0 REQUIRED (OVERLAY Integer ID) Inference Overlay ID
1 REQUIRED (Integer number) Tensor Link ID
2 REQUIRED (true, false) Normalize true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_tensor_normalized/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST:
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_tensor_normalized/", options)
