Api session event editor overlay set service force xy
Revision as of 11:28, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editoroverlay/set_service_force_xy.
API Endpoint name is Api session event editor overlay set service force xy.
Use this endpoint to Set the prefered option to force the CRS order to longitude/latitude for the Service Source of a specified Service Overlay.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Service Overlay ID
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Longitude first (force XY)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_force_xy/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_force_xy/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript example POST:
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_service_force_xy/", options)
