Api session event editor overlay set service crs
Revision as of 11:28, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editoroverlay/set_service_crs.
API Endpoint name is Api session event editor overlay set service crs.
Use this endpoint to Set the prefered CRS for the Service Source of a specified Service Overlay.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Service Overlay ID
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) CRS name
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "CRS name 1" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "CRS name 1", "CRS name 2", "CRS name 3" ] ]'
JavaScript example POST:
 body: '[ 1, "CRS name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_service_crs/", options)
