Api session event editor overlay set overlay source
API Endpoint: editoroverlay/set_overlay_source.
API Endpoint name is Api session event editor overlay set overlay source.
Use this endpoint to Add or remove specified Source to or from a specified SOURCE Overlay. Unincluded Source which are already related to the Overlay will remain related. Unincluded Source which are not related to the Overlay will remain unrelated.
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID (must relate to a SOURCES Overlay) | |
| 1 | REQUIRED | (SOURCE Integer ID or multiple values in array [1, 2, 3]) | Array of Source IDs | |
| 2 | REQUIRED | (true, false) | Should be added to the Overlay (false removes the Source from the Overlay) | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_source/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, false ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_source/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], true ]'JavaScript example POST:
body: '[ 1, 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_source/", options)
