Api session event editor neuralnetwork set neural network
Revision as of 11:27, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorneuralnetwork/set_neural_network.
API Endpoint name is Api session event editor neuralnetwork set neural network.
Use this endpoint to Set Neural Network
0 REQUIRED (NEURAL_NETWORK Integer ID) Neural Network
1 REQUIRED (byte or multiple values in array [a, b, c]) byte[]
2 REQUIRED (String) String
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorneuralnetwork/set_neural_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Text" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorneuralnetwork/set_neural_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], "Text" ]'
JavaScript example POST:
 body: '[ 1, 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorneuralnetwork/set_neural_network/", options)
