Api session event editor measure set geotiff automatic polygons
Revision as of 11:26, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormeasure/set_geotiff_automatic_polygons.
API Endpoint name is Api session event editor measure set geotiff automatic polygons.
Use this endpoint to Let the polygons be calculated automatically based on the GeoTIFFs specified in the GeoTIFF spatial of a Measure.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (Integer number) GeoTIFF Spatial ID
2 REQUIRED (true, false) Automatic calculation true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_geotiff_automatic_polygons/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST:
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_geotiff_automatic_polygons/", options)
