Api session event editor measure duplicate building
Revision as of 11:25, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormeasure/duplicate_building.
API Endpoint name is Api session event editor measure duplicate building.
Use this endpoint to Duplicate specified Measure Building.
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building IDs
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/editormeasure/duplicate_building/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editormeasure/duplicate_building/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editormeasure/duplicate_building/", options)
