Api session event editor measure add
Revision as of 11:25, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormeasure/add.
API Endpoint name is Api session event editor measure add.
Use this endpoint to Add Measure for Stakeholder
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
200 Integer (Measure ID)
curl 'https://engine.tygron.com/api/session/event/editormeasure/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add/", options)
