Api session event editor map set height overlay
Revision as of 11:25, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormap/set_height_overlay.
API Endpoint name is Api session event editor map set height overlay.
Use this endpoint to Update Elevation Model from Grid Overlay
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 OPTIONAL (Integer number) Timeframe (optional)
200 Integer (Amount of sectors updated)
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 0 ]'
JavaScript example POST:
 body: '[ 1, 0 ]'
fetch("https://engine.tygron.com/api/session/event/editormap/set_height_overlay/", options)
