Api session event editor global remove book value
Revision as of 11:24, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorglobal/remove_book_value.
API Endpoint name is Api session event editor global remove book value.
Use this endpoint to Remove Book Value
0 REQUIRED (GLOBAL Integer ID) Global
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorglobal/remove_book_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorglobal/remove_book_value/", options)
