Api session event editor functionoverride reset assets
Revision as of 11:23, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorfunctionoverride/reset_assets.
API Endpoint name is Api session event editor functionoverride reset assets.
Use this endpoint to Reset Assets
0 REQUIRED (FUNCTION Integer ID) Function
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorfunctionoverride/reset_assets/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorfunctionoverride/reset_assets/", options)
